17 years agoasi output clock
I had a problem with the asi output clock. At the output rx_data_clk I've put a pll and i've connected it to the inpiut inclk0, but when i've compiled i got this error:
Error: Clock input port inclk[0] of PLL "pll_3:inst30|altpll:altpll_component|pll_3_altpll:auto_generated|pll1" must be driven by a non-inverted input pin or another PLL, optionally through a Clock Control block Info: Input port INCLK[0] of node "pll_3:inst30|altpll:altpll_component|pll_3_altpll:auto_generated|pll1" is not connected What shpoud I do?1 Reply
You should probably try to rearrange your project and let the input of your PLL come from an external dedicated clock input.
Cheers. OD
