TSuzu6
6 years agoArria10 transceiver PHY rx_control[] issue
Hi! In our Arria10 device, transceiver phy is configured as below, -Transceiver Configuration rules:Basic(Enhanced PCS) -PMA configuration rules:basic -Number of data channels:6 -Data rate:6144...
TSuzu6
6 years agoHi dlim,
Japan is impacted too.
I confirm that "I presume you are using fPLL ? Is the fPLL sitted closer to channel [5:3] or [2:0] ? Does changing to other fPLL helps to resolve the issue here ?"
My FPGA design has 4 instances of the module is included 6CH native PHY.
This issue is occured in one instance of them.
I attach Chip Planner view with comment(.
About Chip Planner view
the issue is occured in #01.
fPLL and Native PHY in the instance #01 are not located in the same bank.
I expect fPLL and Native PHY in the same instance are located in the same bank.
Is this fitting result a resonable ?
Should I modify FPGA configuration(qsf or sdc and so on) ?
BR,
Taira
