Arria10 IOPLL odd phase shift behavior
Hi Gary
From your attachment, we are seeing the setting as below:
.phase_shift0("3125 ps"),
.phase_shift1("3125 ps"),
.phase_shift2("6250 ps"),
.phase_shift3("9375 ps"),
.phase_shift4("21500 ps"),
.phase_shift5("0 ps"),
.phase_shift6("0 ps"),
.phase_shift7("0 ps"),
.phase_shift8("0 ps"),
which are 45degree shifted for outclock2,3,4, which are showing up in the waveform you have attached. Can you further describe the issue you are seeing?
Eng Wei
- GBeck6 years ago
If phase_shift0 is changed to 0 ps there a phase shift present
Also if phase_shift0 is changed to 12500 ps the resulting shift is not 180 degrees.
.phase_shift4("21500 ps"), // 309.6 degrees
.phase_shift8("0 ps"),- GBeck6 years ago
Adding modelsim capture with the following PLL settings
.phase_shift0("0 ps"),
.phase_shift4("12500 ps"),
.phase_shift8("0 ps"),Notice outclk_0 and outclk_4 phase shift is not as expected
- GBeck6 years ago
Eng Wei,
Curious if there have been any developments... Have you been able to re-produce the issue?
Let me know if you have any questions.
Thanks, Gary
