10 years agoArria10 HPS Fpga to Sdram cannot be configured above 64 bits
Hi All,
I want to use the fpga to sdram path in Arria 10 HPS. I want to connect a 256bit AXI interface operating at 125 Mhz from a third party IP to this port. I had a couple of questions:- I cannot select a 256 bit data width in HPS parameter editor. The maximum I can go upto is 64bits.
- If I want to work with 64bit data port but still match the bandwidth (32 Gbps = 256 bits * 125 Mhz) of third party IPs AXI interface, how can I really do it ?
- How do we decide the frequency of the clock for this fpga-to-sdram port.
- Which DDR protocol will QSYS configure in the DDR controller. Will it be DDR3 or DDR4. How does Qsys decide this anyway?
