10 years agoArria10 HPS Fpga to Sdram cannot be configured above 64 bits
Hi All, I want to use the fpga to sdram path in Arria 10 HPS. I want to connect a 256bit AXI interface operating at 125 Mhz from a third party IP to this port. I had a couple of questions: ...
10 years ago --- Quote Start --- Lars_g, Thanks for the reply. Actually I am working on Arria10. When I instantiate a HPS component in Qsys, it does not have any options related to the DDR protocol or the DDR memory width like it has in Arria 5 (under SDRAM tab. The only option it gives me is to enable a conduit to EMIF. 2. You are right. In arria 5 or cyclon 5, you can have a width of upto 256 bits for Fpga-2-HPS-Sdram port, but in Arria10 the maximum width available for selection is 64 bit AXI. In Arria5 or Cyclon, you don't have to manually instantiate the DDR PHY, but what I am thinking is probably in Arria 10, I will have to manually instantiate the external memory PHY. Probably that's why, when I instantiate HPS, its parameter editor does not have any option related to DDR protocol or DDR memory width selection. Now, my real problem is, if I have only 64 bit AXI interafce to the HPS(FPGA-2-HPS-SDRAM interface), I will have to clock it at 500 Mhz to match the bandwidth of my master port(coming from a third party IP 256bit @ 125 Mhz). I am very uncomfortable with such a high frequency(even though this path is really in a hard IP). I don't understand why I cannot have a 256 bit port to HPS sdram interface like I can have in Arria 5. Why altera is limiting bandwidth on this fpga-2-sdram interface to the HPS!!! Let me know what you think. --- Quote End --- I think this is more complicated-- just because the upstream bandwidth is a wider bridge does not mean that the SDRAM controller is running any quicker. I believe the way it worked in the Arria V or Cyclone V was by linking together multiple ports to get increased bandwidth. You could probably do the same here and drive multiple ports, but I haven't messed with it yet. Also, the HPS on the Arria 10 does have an EMIF connection, if you want to play around with that.
