12 years agoArria V delay values (D1, D3, etc.)
On page 59 of the arria v gx, gt, sx, and st data sheet, in the i/o timing section is table 63 about programmable ioe delay. For device -C4, the D1_DELAY has available settings 0-31 with a value of 0...
12 years agoWhen I had similar questions to this I used the Quartus "Resource Property Editor" and just looked at the settings for the I/O delay elements. I'd recommend creating a simple design in Quartus, apply some timing constraints, and then look at those delay settings. You can adjust the TimeQuest delay constraints such that the delay element gets reprogrammed to a new value, so you can quickly confirm that your TimeQuest timing margins have changed by the appropriate delay change.
Cheers, Dave
