16 years agoArria II GX: Transceiver CMU PLL Reset
Hello,I have a problem with resetting my transceiver design.I'm testing on the Arria II GX Devkit and I'm using Quartus 9.1sp1.Sometimes after I pushed the reset button the transmitter sends wrong bi...
16 years agoPlease check if the pll_locked signal de-assertion when you assert pll_powerdown? There is one issue on Arria II GX's pll_locked signal which is similar to Stratix IV device. Refer to Stratix IV errata for the workaround(www.altera.com/literature/es/es_stratixiv_gx.pdf )
