16 years agoArria II GX DDR2 issues with .QSF file
I have been banging my head against a wall for the last day and I hope I can get a solution to this. Challenge: Generated a HPCII DDR2 controller using the Megawizard, not an issue. The top ...
16 years agoIO Standard for DQS/DQSn should be Differential SSTL-18 Class I. When you enter pin AM25, edit the differential column and change mem_dqs[0](n) to mem_dqsn [0]
I spent some time on this and finally got the example_top to work. The documentation and material that comes with the kit is very hard to follow and not as complete or clear as it could be.
