16 years agoArria II GX + DIMM = no more than 12 HSTL/SSTL output or bi-directional pins are allo
I'm trying to get my EP2AGX45 (572 package) Arria II GX to interface with a DIMM. I've run into an apparent limitation of 12 SSTL signals per I/O bank. It seems i will have to move up to the top devi...
15 years agoAs far as I see, a 64-Bit DIMM can be operated from 3 IO banks in the 572 and 780-pin package. The limiting factor is the number of availiable DQS groups. The said "limitation of 12 SSTL signals per I/O bank" is caused by incomplete pin assignments.
