15 years agoArria II DDR2 clock assignment
Hello, I am trying to use 2 x16 DDR2 chips and combine them as 1 x32 DDR2 using the HP DDR2 IP. I am using differential DQS and have one CK/CK# pair per chip. In the emi_plan_pin document...
15 years agoHello,
I am trying to use 2 x16 DDR2 chips and combine them as 1 x32 DDR2 using the HP DDR2 IP. I am using differential DQS and have one CK/CK# pair per chip. In the emi_plan_pin document (version 2.0) page 2-16, it says that if I use diff DQS, I have to put the first clock pair in a pin with DIFFIO_RX or DIFFIN and the second clock in a pin with DIFF_OUT in the same single DQ group. In the Arria II package I am using, each x8 group allows a max of 12 pins to be used. So, 8 DQ + 2 DQS is 10 pins leaving 2 pins for other assignments. Since I need 4 pins to put both clocks in the same DQ group, I will have to use a DQ group that does not have DQ/DQS pins. Can I split the 2 clocks into 2 different DQ groups? If I want to put the two clocks in a separate DQ group that I also use for other signals such as address and odt, does it matter where that group is located? My question is probably a little confusing; I can clarify any part if needed. Thank you for you help!
