smile123's avatar
smile123
3 years ago
arria 10 use transciever phy ip
hi,everyone,i have a issue about transciever phy ip,as follows:
the phy ip is 2 recieve channel,but the rx_is_lockedtoref signal of ch1 is unstable, ch0 is ok.
At the same time,i have a phy ip is 1 recieve channel to test the ch0 and ch1, all off them is ok,What is the problem?
  • Hi smile123,
    When CDR is in locked to data mode, the status of rx_is_lockedtoref is unknown; it can be high or low or toggling. You do not need to care about rx_is_lockedtoref when rx_is_lockedtodata is high.
    zying
  • ZiYing_Intel's avatar
    ZiYing_Intel
    Hi smile123,
    zying
    • smile123's avatar
      smile123
      ok,thank you for your reply。
    ZiYing_Intel
    Hi smile123,
    Can you share your .qar file here? So that I can try debug the issue from my side.
    zying
    ZiYing_Intel
    Thanks for submitting the issue. Allow me have some time to look into the issue and I will get back to you with findings.
    zying
  • FvM's avatar
    FvM
    you agree that you are not giving much info about your design?
    As a starter question, does your design meet timing? Do you see any warnings, e.g. related to PLL usage?
    • smile123's avatar
      smile123
      Hi,it is sorry to reply to you now,my .qar project file is below.
