smile123
3 years agoarria 10 use transciever phy ip
hi,everyone,i have a issue about transciever phy ip,as follows: the phy ip is 2 recieve channel,but the rx_is_lockedtoref signal of ch1 is unstable, ch0 is ok. At the same time,i have a ph...
- 3 years ago
Hi smile123,
When CDR is in locked to data mode, the status of rx_is_lockedtoref is unknown; it can be high or low or toggling. You do not need to care about rx_is_lockedtoref when rx_is_lockedtodata is high.
zying
ZiYing_Intel
3 years agoHi smile123,
zying
- smile1233 years ago
ok,thank you for your reply。
