10 years agoArria 10 sw warm and cold reset does not work
When i issue a reset in uboot or a reboot in linux, the hps seems to hang/stall but doesn't reset. When i write a 0x01, 0x02 or 0x03 into the i_rst_mgr_rstmgr register at addr 0xFFD0500C, i have t...
10 years agoHi, did you find a solution to this reset problem? We have the same problem, when issuing reset from u-boot, HPS hangs. (Dev kits are working - With and without any firmware). We are looking into the HPS handover to see if there is a register maybe to enable? Could not find anything yet. So now i am of the opinion that there maybe a problem in the PCB layout, e.g. Is there a hard reset output which i need to feedback to a hard input? We are using Cyclone V SOC. Thanks
