[Arria 10 SoC] QSPI Flash GigaDevice Compatibility (GD55LB02GE / GD55LB02GF)
Hi Altera Community Support Team,
We are currently using the Micron MT25QU02G as the primary QSPI boot device for our Arria 10 SoC (HPS) board. However, due to a severe unit price increase (nearly 20x), we are urgently looking for a cost-effective alternative QSPI Flash memory.
During our search, we identified GigaDevice NOR Flash products as potential replacements. However, checking the "Supported Flash Devices for Arria 10 SoC Device" configuration page, GigaDevice is not listed under the Arria 10 SoC section, even though GigaDevice parts are mentioned as supported/compatible for several other FPGA/SoC device families.
https://www.altera.com/developers/configuration
I would like to ask the following questions:
Arria 10 SoC Compatibility: Does the Arria 10 SoC HPS BootROM support booting from GigaDevice 2Gb 1.8V QSPI Flash devices? Since the BootROM operates using standard JEDEC SFDP and basic SPI opcodes, can we expect it to load the preloader/U-Boot SPL without issue?
GD55LB02GE vs. GD55LB02GF: Our target part was initially the GD55LB02GE, but we found that it is becoming NR (Not Recommended) / NRND, and the newer generation revision GD55LB02GF is being recommended for new designs. Are both GD55LB02GE and GD55LB02GF supported as boot devices for Arria 10 SoC? Are there any known issues with JEDEC ID parsing or SFDP compatibility in U-Boot / HPS Flash Programmer for the newer F-revision?
Programming Tooling: Will quartus_hps or the HPS Flash Programmer support flashing these GigaDevice parts directly, or would we need to handle programming via U-Boot / JTAG scripts?
Any advice, official guidance, or experience regarding GigaDevice QSPI Flash migration on Arria 10 SoC would be greatly appreciated.
1 Reply
- ai_responder
Community Manager
Good question, and I understand the urgency given the pricing situation. Let me work through your three questions carefully based on what's documented for Arria 10 SoC.
1. Arria 10 SoC HPS BootROM Compatibility with GigaDevice
GigaDevice is not listed in the Supported Flash Devices for Arria 10 SoC page — you've confirmed that yourself. The specific parts GD55LB02GE and GD55LB02GF do not appear anywhere in my available documentation for Arria 10 SoC HPS boot support, so I cannot confirm or deny them as verified boot devices.
What I can tell you is what the Boot ROM actually requires, so you can assess compliance yourself:
- The boot ROM code configures the QSPI controller to default settings for the supported SPI or quad SPI flash memory. Arria 10 SoC Boot User Guide Those defaults are fixed — the Boot ROM does not parse JEDEC SFDP at boot. It uses hardcoded register values.
- The read opcode in non-XIP mode is
rdopcodein thedevrdregister =0x3(for normal read) and0xB(for fast read). Arria® 10 Hard Processor System Technical Reference Manual Your GigaDevice part must support both of these standard opcodes. - The default instruction type is Single I/O (1 bit wide); the address transfer width (
addrwidth) and data transfer width (datawidth) of thedevrdregister default to 0. Arria® 10 Hard Processor System Technical Reference Manual - The number of address bytes defaults to 3 bytes (
numaddrbytesindevsz= 2). Before a reset, you must ensure that the QSPI flash device is configured to 3-byte address mode for the boot ROM to function properly. Arria® 10 Hard Processor System Technical Reference Manual - BSEL value 0x6 selects a 1.8 V quad SPI flash memory. Arria® 10 Hard Processor System Technical Reference Manual
For a 2 Gb (256 MB) device, 3-byte addressing only covers up to 128 MB (16 MB address space). The Boot ROM only needs to reach the second-stage boot loader (SPL/preloader), which is located at offsets that are multiples of 256 KB Arria 10 SoC Boot User Guide — so 3-byte addressing is sufficient for the boot stage as long as the SPL image fits within the first 16 MB. The concern is that after the SPL runs, it may switch the flash to 4-byte mode; if a QSPI flash has been switched to 4-byte addressing during operation, you need to ensure it is returned to its default 3-byte addressing mode whenever the HPS is reset, otherwise the HPS cannot boot from or access the QSPI chip. Methods include asserting the flash reset pin on HPS reset, or power-cycling the flash. QSPI Flash Interface Design Guidelines
Also critical for your board design with BSEL=0x6: The QSPI_SS1 pin is also used as BSEL0. When selecting BSEL=0x6 (1.8V QSPI), QSPI_SS1 cannot be directly connected to the QSPI chip select. As HPS BSEL values are sampled on cold reset deassertion, you must decouple QSPI_SS1 from the chip select — for example, via an external buffer with a pull-up on the flash side. Once the HPS exits cold reset, QSPI_SS1 is driven correctly. QSPI Flash Interface Design Guidelines
2. GD55LB02GE vs. GD55LB02GF
Neither part number appears in any available Altera documentation for Arria 10 SoC. I cannot make any statement about JEDEC ID parsing, SFDP compatibility, or Boot ROM support for either revision. The distinction between the E and F revisions is entirely outside the available documentation.
The design guidelines recommend using an "Intel Tested and Supported" device if at all possible, to minimize development effort and eliminate incompatibility risk. The next-best option is a "Known to Work" device — one compatible with Boot ROM and proven with at least one bootloader — but that may not have HWLIBs, OS support, or HPS Flash Programmer support. Flash Device Driver Design Considerations
Practically: if you want to qualify a GigaDevice part, you'll need to verify against the Boot ROM opcode requirements above, and you'll need to validate the U-Boot/SPL driver separately since GigaDevice is not on the officially supported list for Arria 10 SoC.
3. HPS Flash Programmer (quartus_hps) Support
The HPS flash programmer supports Quad SPI (QSPI) Flash and ONFI-compliant NAND Flash. Quartus® Prime Pro Edition User Guide The HPS Flash Programmer supports Arria 10 SoC devices. Altera SoC FPGA Embedded Development Suite (SoC EDS) User Guide However, the programmer identifies flash by silicon ID: the quartus_hps programmer may fail during programming if the QSPI contains an existing or corrupted image. Error messages include "Fail to read Silicon ID" and "Quad SPI Flash silicon ID is 0x00000000." Why does quartus_hps fail to reprogram my QSPI device?
The only GigaDevice part confirmed in the available Quartus Prime programmer supported-device table is the GD25Q127C (3.3 V, 128 Mb) — your 1.8 V 2 Gb GD55LB02GE/GF parts are not listed. This means
quartus_hpsmay not recognize their silicon IDs and could fail.Your fallback options if direct
quartus_hpsprogramming fails:- The Customizable Flash Programmer enables users to program third-party flash devices (Winbond, Macronix, Cypress) with an FPGA configuration bitstream or raw programming data (.rpd) via System Console. This design example is the Programmer Image for Arria 10 FPGAs. Design Details You can adapt the TCL scripts for GigaDevice opcodes — the TCL script can be customized to perform any quad SPI flash command, such as programming flash registers to set 4-byte addressing, dummy clock cycles, and the quad enable bit. Customizable Flash Programmer User Guide
- For HPS boot image programming specifically, U-Boot's flash commands are a fully supported alternative path, as described in the Arria 10 SoC design guidelines.
Summary / Recommendation
GigaDevice is not an officially supported or validated vendor for Arria 10 SoC HPS boot in the available Altera documentation. If you proceed, you'll need to: (1) verify that your chosen part supports standard
0x03/0x0B/0xEBread opcodes in SPI mode at power-on; (2) ensure the flash starts up in 3-byte address mode (or implement a hardware reset scheme as described above); (3) plan for U-Boot/SPL driver development or adaptation; and (4) expect thatquartus_hpsmay not natively recognize the silicon ID and use the Customizable Flash Programmer or U-Boot as your programming path instead.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
