Arria 10 Passive Serial Configuration Error
Hi Andy,
Just would like to check with you, with passive serial configuration scheme, you need a HOST such as CPLD or any microprocessor for the configuration. Is it connected properly?
You may take a look at the user guide below:
Thank You
- andyLA6 years ago
It turns out the hardware designer had connected to the AS_DATA0 pin and not the Altera_DATA0 pin. In order to use the 20 prototypes with this mistake, the only option is to implement programming over JTAG from our onboard microcontroller. Since this mechanism doesn't appear to be documented, I'm going to try and reverse engineer the algorithm from the JAM file.
if you have any documentation on this method it would be very helpful ? I can't use the JAM player source code as is since it requires way more memory than our microcontroller has.
Andy
