BHoey
7 years agoArria 10 HPS peripheral routing - EMAC/MDIO - Shared IO/FPGA IO
I need to repurpose some IO in a HPS Shared IO sub-bank that contains the MDIO pins. These repurposed pins need to be driven from the FPGA fabric. A Shared IO sub-bank cannot only be HPS-driven OR ...
SreekumarR_G_Intel
7 years agoHello Brian,
Can you look at the HPS technical reference manual in below link Figure 120 and Figure 121 ?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_5v4.pdf
Either using custom logic or using the IP you can use route to the FPGA PAD.
Bit confused with your question, you want MDIO is routed to FPGA and MAC signal routed via HPS Shared IO ?
Thank you ,
Sree
