8 years agoArria 10 Dev Kit Max II and USB microcontroller
Hi I am designing a board similar to Arria 10 Dev Kit and want to add USB Blater II functionality. Do altera or any one has firmware for Max II and USB microcontroller? or do i have to write by...
8 years agoHi,
You cannot get the protected IP from Altera. There may be other open source versions that you could try on your own, but you wont get support from Altera for that. https://github.com/mithro/ixo-usb-jtag You could try look at the above link for starters. Protected IP is not available for general public, it may be available as an CPLD with built-in code from Altera that you could buy and use in your project. But this will have the functionality already in it and you will not be able to download/modify it. Abr
