8 years agoArria 10 Dev Kit Max II and USB microcontroller
Hi I am designing a board similar to Arria 10 Dev Kit and want to add USB Blater II functionality. Do altera or any one has firmware for Max II and USB microcontroller? or do i have to write by...
8 years agoRas, you will not be able to simply read a pof from the CPLD in a USB-Blaster. It's a protected Altera IP. It's not this simple. If you have an 'instruction' or requirement for this in a design then the requirement is flawed - unless you work for a trusted Altera partner.
Anand, I cannot believe that you, who claim to be posting 'on behalf of Intel Corporation', are encouraging forum members to download Altera protected IP, regardless of how futile your suggestion is. The language you use in your posts clearly implies you work for Intel. There a many Altera/Intel employees who do contribute regularly to this forum. I'm sure Intel, who also monitor this forum, would have something to say to any employee promoting the theft and piracy of their own products. Alex
