fpga6
3 years agoArria 10 ASDATA Flash interface
Hi, I am using an Intel Arria 10 FPGA. Is it possible to access the pins ASDATA0/1/2/3 and DCLK to read/write to the configuration flash during user mode, without using Intel's "Generic serial fla...
- 3 years ago
Issue resolved, flash problem due to failed/stuck bit in volatile configuration register.
Solution to accessing Arria 10 ASDATA/DCLK pins, without using Intel IP, during user mode is to use Arria 10 primitives.
fpga6
3 years agoIssue resolved, flash problem due to failed/stuck bit in volatile configuration register.
- smile1231 year ago
Hi,now,i want to do what you do,but the twentynm_asmiblock code,i don't know how to use the twentynm_asmiblock code,can you help me about this?thank you very much。
