fpga6
3 years agoArria 10 ASDATA Flash interface
Hi, I am using an Intel Arria 10 FPGA. Is it possible to access the pins ASDATA0/1/2/3 and DCLK to read/write to the configuration flash during user mode, without using Intel's "Generic serial fla...
- 3 years ago
Issue resolved, flash problem due to failed/stuck bit in volatile configuration register.
Solution to accessing Arria 10 ASDATA/DCLK pins, without using Intel IP, during user mode is to use Arria 10 primitives.
FvM
3 years agoHello,
why should it not be possible? The method is just the same as using ASMI Parallel without dedicated AS interface, connecting asmi pins on the design top interface.
I found however, that ASMI parallel IP is well suited for similar purposes, with a few modifications like gating DCLK and possibly tri-stating asmi pins if concurrent devices are driving the flash in your design.
Frank
