KBrit1
7 years agoArria 10 10AX016E4 device no longer detected by JTAG Scan, wont load program, can't reprogram
I was able to use my USB Blaster in JTAG mode to program my A10 board. Once it was successfully Programmed and Verified, I cycled power to had the A10 load its configuration. It did not load, and now...
YuanLi_S_Intel
7 years agoHi Ken,
Based on your explanation, are you saying that you apply the same JIC into the development kit, first and last 1/3 batch is working fine but not 2nd 1/3 batch? Please clarify.
Also, may i know how many pieces of development kit is having problem on the second 1/3 batch? If some unit is having this issue, it might be caused by development kit problem and you can apply RMA for that.
YL
