KBrit1
7 years agoArria 10 10AX016E4 device no longer detected by JTAG Scan, wont load program, can't reprogram
I was able to use my USB Blaster in JTAG mode to program my A10 board. Once it was successfully Programmed and Verified, I cycled power to had the A10 load its configuration. It did not load, and now...
YuanLi_S_Intel
7 years agoHi Ken,
CONF_DONE pin stays LOW means that the board is having configuration error. Can you try to load a SOF file and see if it works?
YL
