14 years agoARIA V memory resource usage
Hello, I've created a memory block with megawizard for ARIA V component. Memory size is : 524288bit when I use the same data width for write and read (16bit for example) the resource usage is ...
14 years agoPerhaps the memory block is just being duplicated ?
If there is enough memory on the device this might be done in order to remove some logic.
