14 years agoARIA V memory resource usage
Hello, I've created a memory block with megawizard for ARIA V component. Memory size is : 524288bit when I use the same data width for write and read (16bit for example) the resource usage is ...
14 years agoI am using Simple Dual-Port RAM with 1 read and 1 write port but with different clocks (read clock, write clock) and different bus widths.
i am looking at "M10K Block Mixed-Width Configurations (Simple Dual-Port RAM Mode)" table and it says it supports write 512x16 and read 256x32. Can you please explain?
