17 years agoArggh! Error: Can't find port "ocp_enable" in OpenCore Plus entity "auk_ddr_hp_init".
Hi there I have a really annoying problem on Quartus 8.1 when compiling designs that feature SOPC with DDR Error: Can't find port "ocp_enable" in OpenCore Plus entity "auk_ddr_hp_init". -- Ope...
17 years agoWhat's more infuriating is the tutorial and demos don't run until you build the PTF and SOF files. And the tutorial says to start with cycloneIII_3c25_niosII_standard_sopc for Hello World. Great for that, but that default to be used for demos doesn't include Ethernet support. So, you can create a project starting with Sample Socket Server or WEB Server and it doesn't have the logic to do Ethernet! Is this me or did you find the same thing?
