10 years agoAre VCCA pins connected internally on dual supply MAX10
We are using a 10M04DAF256C8G MAX10 and have a board layout issue we are trying to recover from without scrapping a bunch of assembled boards. There are some (not so pretty) options for reworking but...
10 years ago --- Quote Start --- Altera don't publish such information - you could consider asking them for it. However, I suspect they'll just point you at the datasheet and, effectively, say that if the datasheet states they're VCCA pins, then they're connected. You could try a continuity test on a device that's not soldered down. Buzz out between E12 (and L5) and other VCCA pins. I suspect you'll be disappointed and find they're all connected... --- Quote End --- Thanks.. I planned to continuity test when I pulled a part off a board.. don't have any loose ones at the moment. I know this is a long shot but something to check in case one is lucky.
