12 years agoAre Stratix V IOE delays programmable dynamically?
Are Stratix V IOE delays programmable dynamically? The documentation I found so far seems to say that the delays are programmable but it seems you set the delay once at compile time and it doesn't ch...
12 years agoHi John,
The ALTIOBUF looks like its been available since Stratix III series or so; http://www.altera.com/literature/ug/ug_altiobuf.pdf "Can enable dynamic delay chains for I/O buffers" I'd agree that this appears to provide the functionality you are looking for. The scan chain interface is similar to the interface on PLLs (that Pete and I have used for dynamically adjusting PLL parameters). I'd recommend instantiating this component and simulating it using Modelsim. If you synthesize a design, you should be able to view the "default" settings of the IOE delay buffers using the "Resource Property Editor". Cheers, Dave
