16 years agoAppropriate ADC for educational project?
Hello folks! I'm a student of 'Network Systems and Data Communications' department in Greece and am doing my final project/dissertation right now in Leiria, Portugal at Electrical Engineering d...
16 years agoDear Amilcar,
On the Verilog Code tou sent to David, at the Declaration, --- Quote Start --- input wire clk, // the main FPGA clk (its faster than the ADS1204 clk) input wire reset, // async reset input wire i_ds_clk_out, // the ADS1204 clk (derived from the main clk) input wire i_ds_out, // DS modulated output bit output reg signed [ADS1204::ENOB(DECIMATION)-0:0] o_result, // one extra bit for the sign output reg o_valid = 1'b0); // the result is new and valid --- Quote End --- In our application we want to encapsulate on the payload of UDP packets, so we will fill a buffer with the words from the ADC, 1. the " o_result" contains a word of how many bits? and 2. on how many clock cycles i will have one word? Also i want more than 12bits resolution for this audio application so what Decimation M number i will use? Sorry for asking all these but im Still confused!!! Thank you again!!!! Greetings From Beautiful Leiria!!!!
