16 years agoAppropriate ADC for educational project?
Hello folks! I'm a student of 'Network Systems and Data Communications' department in Greece and am doing my final project/dissertation right now in Leiria, Portugal at Electrical Engineering d...
16 years agoYes, you can send 20MHz clk to the ADC, but that ADC will send you a clk signal back, and you need to use that one to clock the data in.
You can and should build the low pass filter together with the decimation of the delta-sigma. And the best way to achieve that on an FPGA is to implement the sinc3 filter described in the application notes of that chip. I can send you the code if you want. I have no experience with the NE5532.
