16 years agoAppropriate ADC for educational project?
Hello folks! I'm a student of 'Network Systems and Data Communications' department in Greece and am doing my final project/dissertation right now in Leiria, Portugal at Electrical Engineering d...
16 years agoFvm, thank you for your reply!
I'm sorry of not mentioning the bit-resolution I've thought about, but I was actually also considering of using a 12-bit resolution ADC. Thank you anyway! amilcar, what nice coincidence! I checked out the ADC you recommended, and it looks good to me! Just a few things to clear out... I saw that I can use an external CLK in mode 3 of ads1202 for application requirements, so that I can synchronize the data output with the fpga. That's important to me because I need to transmit data from the fpga via 10Base-T Ethernet which needs 20 MHz of minimum bandwidth. Is that right? Also, due to oversampling of the device and the integrated DSP I won't need any further low-pass filter, is that so? Finally, I thought of using NE5532 pre-amp as an op-amp. Will this work together properly? Thank you all for your time!
