18 years agoAnyone used the video sync generator in Quartus 7.2??
The reason I ask is that it is confusing me a lot. The documentation says that the RGB output has a variable width that is configurable via the 'data stream bit width' variable (if no one believes...
18 years agoI had a response from Altera support, after kicking up a fuss, that there is indeed a bug with the IP block. I have also got a contact within Altera who sent me a modified .tcl script and an alternative vhdl block that will clock in 8 bits per 3 beats and output them in one 24 bit wide O/P. That saved me the effort!
