18 years agoAnyone used the video sync generator in Quartus 7.2??
The reason I ask is that it is confusing me a lot. The documentation says that the RGB output has a variable width that is configurable via the 'data stream bit width' variable (if no one believes...
18 years agoYou can find the altera_avalon_video_sync_generator_hw.tcl file in the
/ip/sopc_builder_ip/altera_avalon_video_sync_generator/ path. Use some editor to open it, and get into line 103. Change that 8 to be $data_stream_bit_width Then you will get the proper result -Dylan
