18 years agoAnyone used the video sync generator in Quartus 7.2??
The reason I ask is that it is confusing me a lot. The documentation says that the RGB output has a variable width that is configurable via the 'data stream bit width' variable (if no one believes...
18 years ago --- Quote Start --- The reason I ask is that it is confusing me a lot. The documentation says that the RGB output has a variable width that is configurable via the 'data stream bit width' variable (if no one believes me, it's on page 4 clearly in black and white). I set this to 24 bits and a 'beat per pixel' of 1, just like the example given in the documentation, as this fits my requirements. The system generated fine in SOPC builder but the symbol in Quartus shows the output having just 8 bits......how can a 24-bit per pixel O/P be sent in an 8-bit wide O/P???? :confused: I have read over and over the documentation and nothing in it states that the O/P is fixed at 8-bits and Altera support are being useless (3 weeks and no reply)....even though they designed the IP block :mad: Has anyone else found the same behaviour? --- Quote End --- Did you had any success on using the video sync generator jet?
