16 years agoAnyone ported AN532 PCIe to Arria2GX dev kit?
Has anyone ported the PCIe reference design for App Note 532 to the Arria II GX dev kit - and had the PC host GUI work? If so, can you share the project or any insight? -Thanks
16 years agoFrederik,
All inputs at the top level can be left unconnected. In VHDL, just declare a signal called gxb_powerdown_pcie_compiler_0_sig and connect that to the vhdl instantiation. DO the same for the other inputs. You can use the 125Mhz clock output from the PCIe IP as your application input clock instead of the local_clock. The MOST IMPORTANT signals is actually the test_in, see below: test_in(39 downto 16) <= (others => '0'); -- selects the layer to output onto the test_out bus test_in(15 downto 13) <= "000"; -- selects the Lane test_in(12) <= '0'; -- selects VC test_in(11 downto 8) <= "0010"; -- 0000 = Transaction Layer, 0010 = PHY-MAC outputs test_in(7) <= '0'; -- Disable low power state negotiation test_in(6 downto 5) <= "00"; -- b5 = completely disables compliance mode; never enter compliance mode -- b6 = forces compliance mode. test_in(4) <= '0'; -- Remote Boot mode test_in(3) <= '1'; -- FPGA mode. Set to '1' for an FPGA implementation in order to appear compliant to other PCI Express components. test_in(2) <= '0'; -- Descramble mode test_in(1) <= '0'; -- Loopback Master test_in(0) <= '0'; -- Simulation mode Regards, Peter
