(AN741) Nios cannot erase on-chip FLASH
- 6 years ago
Hi, Junbum
You can find the start and end address of CFM1 (for your application image) in the .map file when you generate the .pof.
You need to copy and paste the block with above start and end address into a new .rpd (for the application image to be updated remotely). But in newer Quartus versions, you don't have to do that, there is a .rpd automatically generated for CFM1.
You need to create a quartus.ini in your project directory, and put below line in it, before you do covert programming file to .pof from your application .hex.
PGMIO_SWAP_HEX_BYTE_DATA=ON
Eric
Hi, Junbum
Do you have any more inquiry ?
Eric
I was able to partially solve this problem apart from the previous answer. When using Interval Timer in QSYS, the above error occurred. And when deleting Interval Timer, it was confirmed that Remote System Update can be used normally. I want to know how to solve these problems.
And i use Quartus Prime Lite Edition 17.0
