12 years agoAn all-in-one Software Defined Radio platform
Hi, I'm building the analog front end for my software defined radio receiver architecture. The ADC will directly sample the bandwidth of interest to basband where the the information can be pas...
12 years ago --- Quote Start --- I'm new to SoC devices, but could it be possible to replace all this with a SoC device - doing digital down conversion and signal processing algorithms in the FPGA, effectively replacing the current IC. Then use the ARM core as the host micro... Am I on the right track? --- Quote End --- Yes, an SoC device plus the external ADC could replace what you have now, but so could; 1) An FPGA with a soft-core processor. 2) An FPGA connected to a "real" processor. The advantage of the SoC though is that it has a "real" processor in the same package as the FPGA, so you have ample resources to connect the two, and much more processing horse-power than the NIOS II soft-core processor. Given the choice between the ARM processor and the NIOS II, I'd go for the ARM. That being said, the SoC devices are new, so there is still a lot of teething to be had. Up until now, I have been using (2), as my processing solution, but its a pain, since you often need lots of glue logic to match the processor bus to the FPGA. Go ahead and have some fun, look at the SoC devices :) Cheers, Dave
