12 years agoAn all-in-one Software Defined Radio platform
Hi, I'm building the analog front end for my software defined radio receiver architecture. The ADC will directly sample the bandwidth of interest to basband where the the information can be pas...
12 years ago --- Quote Start --- Do Altera's cyclone FPGA kits have the capability to use this FMC adapter board? --- Quote End --- This Arria V kit has an FMC connector http://www.altera.com/products/devkits/altera/kit-arria-v-gx.html --- Quote Start --- I do not have an FPGA kit yet. It may be best to select the FPGA board I need to develop the software. Then create an adapter board to interface the ADC to the particular Altera FPGA kit as you said. --- Quote End --- You need to be very careful to select a board that matches your data bandwidth requirements. However, if you are trying to implement "software defined radio" why even bother with an FPGA. That would be a "hardware defined radio", albeit reprogrammable :) Also selecting an ADC with a clock rate of 40MHz is not exactly going to get you much. Were you planning on interfacing it to a digital downconverter? Here's a more reasonable looking SDR platform ... http://www.kickstarter.com/projects/mossmann/hackrf-an-open-source-sdr-platform Cheers, Dave
