12 years agoAn all-in-one Software Defined Radio platform
Hi, I'm building the analog front end for my software defined radio receiver architecture. The ADC will directly sample the bandwidth of interest to basband where the the information can be pas...
12 years agoI appreciate your help - Yes, I have got the ADC evaluation board for the AD9629-40 as well as the High Speed Data Capture Kit (the exact set up from the link you sent). Do you know if it's possilbe to code the Virtex 4 on the High Speed Data Capture Kit for radio applications?
I am building the analog front end and the ADC onto a PCB as a prototype for product manufacturing. Initailly, my plan is to build the PCB and replace the ADC evaluation board, so it can connect to the High Speed Data Capture Kit for further evaluation using SPI controller and VisualAnalog. Then replace the High Speed Data Capture Kit with an FPGA board to develop my code in software. Does Altera have FPGA boards that can connect to the AD9629-40 ADC evaluation board ? Thanks again, Les.
