17 years ago
am I a complete noob?!
after a lot of time, I managed to load a simple c program into the nios2
now the problem is that when I use the NIOS IDE to load it, it just hangs(the board), and when I use the monitor program, for something to happen I have to keep switching from pause to run mode....
here is the c code:
# define Switches (volatile char *) 0x0011000
# define LEDs (char *) 0x0011010
int main()
while (1)
*LEDs = *Switches;
return 0;
LE: ...I fixed it!...kinda
i was using a NiosII/f processor. After switching to a NiosII/e, everything works fine.
Why did that happen?
    Thanks for your reply!
    I think I got it now...I'll get back to you if I still have some problems.
    thanks again!
    How are you bypassing the d$, assuming you have some? The keyword volatile will not bypass the d$. You either have to use the IORD/IOWR macros or bypass the d$ by ORing your address value with bit 31 set high.
    How do you know it's hanging? Have you tried debugging it in the IDE?
    UPDATE: The "e" core has no d$, so you weren't (and aren't) bypassing the $, which is what you have to do when accessing hw registers.
    Best of luck!
    - Ura
