raviganesh
6 years agoALTPLL Clock switchover in Cyclone 10 LP
I am using the ALTPLL to generate a 80MHz clock from a 48MHz clock. This is fine. Later when an independent clean 80MHz clock is available I am switching over to this clock by using the clock switch...
JonWay_altera
6 years agoHi @User15891149574421405910 I am not sure what random problems you are referring to...but i guess it depends on your application. As a rule of thumb, as long as the PLL is locked, the output is reliable.
