14 years agoAltmemphy and DDR question
Where can I find timing info for Altmemphy. I am trying to do signal integrity analysis of FPGA and DDR2 interface. I need clock to DQS delay min/max, DQmin, max etc. I am a bit confused about ...
14 years ago --- Quote Start --- I'm a beginner myself but I believe you need the timing info from the memory chip datasheet and use these in the sdc constraints so that the fitter can optimize the paths to accommodate the latencies. --- Quote End --- I am looking for timing after the fitter optimizes the paths. The tool I am using for signal integrity simulation is hyperlynx. I need to enter the timing info of the controller to get any timing violation if any. --- Quote Start --- The numbers in both DDR-400 and DDR2-400 stand for the maximum amount of transfers per second which is the same 400MT/s for both modules. For DDR this gives a transfer rate of (internal memory clock rate) × 2 (DDR) × 64 (number of bits per transfer) / 8 (bits per byte) For DDR2 this gives a transfer rate of 2 x (internal memory clock rate) × 2 (DDR) × 64 (number of bits per transfer) / 8 (bits per byte) But since the internal memory clock of DDR2 is two times lower, they both result in the same throughput. For both modules, the externally applied I/O clock rate is 200Mhz for both modules. In short, DDR-X and DDR2-X memories with the same value X have the same maximum data rate and the same externally applied clock rate of X/2. Difference is that the internal memory clock of DDR2 is two times lower than the one of DDR and most likely some differences in internal latencies. N. --- Quote End --- Regarding the transfer rate, why do you multiply by 64? For DDR3-800, the external clock would be 800/2 = 400MHz? But wiki says, DDR3-800 Memory clock speed is 100MHz?:eek:
