10 years agoALTMEMPHY - No Clocks - RefClk Slew Rate Requirements?
I'm debugging a Cyclone IV E design. The DDR2 interface is dead in hardware but simulates okay. Signaltap shows two out of three DIMM clocks dead. I scoped the 50 MHz reference clock and the rise and...
10 years agoI have, via Signaltap, traced the error to a failure in the below altmemphy state:
State.s_rrp_seek Read resynchronization phase setup stage: set PLL to center of valid window. dgrb_ctrl.command_err Error in the data gather read bias block. dgrb_ctrl.command_result[7..0] Data gather read block (DGRB) error code. The error code is 05h. Can anyone shed some light on what, exactly, this means? I will do my best to Google for an answer... STP screenshot attached. Thanks!
