18 years agoaltlvds_tx Stratix III
Hello, when I use the altlvds_tx megafunction, it has a default setting of "tx_coreclock" for registering the input data (which I leave as set). Does this setting require that I enable the tx_cor...
18 years agoHello,
It's always best to register the incoming data with the tx_coreclk, this is an internal connection within the logic and you don't have to turn on the tx_coreclock output port. If you want to forward the tx_coreclock to an output pin, then you would turn on this port. -- Desert Rat
