ALTLVDS_RX input clock jitter mitigation
Hi Eng Wei
thanks for your reply.
We are using ALTLVDS_RX in non-DPA mode.
Hi User Von SCS
Are you able to try out DPA mode to overcome your design issue?
Eng Wei
- UVonS6 years ago
Hi Eng Wei
I only have limited understanding of the ALTLVDS_RX DPA mode.
We are seeing spurious clock jitter at the ALTLVDS_RX clock input which in turn seems to cause wrong acquisiton of the data (ALTLVDS_RX PLL lock remains). So "usually" transmission is working fine, and only sometimes this clock jitter occurs in the transmitting device for a short time causing CRC errors. Ideally we want to avoid CRC completely in this case.
Can DPA mode be used to solve this kind of problem?
- EngWei_O_Intel6 years ago
Hi User Von SCS
It really depends on how the jitters look like. If it is a phase shift, it will work. If the clock is heavily distorted, then problem might still exist.
Using external PLL allowing us to control parameters like bandwidth setting, it might or might not help depends on the jitters behaviour.
The best solution is still fixing the source that is causing the jitters, as a clean source is important to feed FPGA.
Meanwhile, I will be off for a week from now. Allow me some time to get back to you if you have further question.
Eng Wei
Hi User Von SCS
Are you able to resolve the issue?
Eng Wei
