MrZaiko
5 years agoaltfp_add_sub not working on standard Quartus 20.1
Hello, I'm using quartus standard version 20.1. I want to use the altfp_add_sub megafunction. However, after generating the megafunction using the MegaWizard Plug-In Manager, when I try to synthesiz...
MrZaiko
5 years agoHello,
Thank you for your answer! I named the IP adder and my instantiation seems to be correct (it matches the _inst file). Moreover, the error is in the adder.vhd file generated by the parameter editor. I'm sorry if I got the words wrong.
I have attached a screenshot of the instantiation of the IP in my code as well as the adder_inst.vhd and adder.vhd generated by the parameter editor.
Thank you
RichardT_altera
5 years agoHave you upgrade the IP when migrate to the latest Quartus version?
Try to rebuild the project to check if the issue persists. Also check that the device used is supported in the document below.
