13 years agoAltera USB-Blaster II Design
Hello, I was given instructions on building my own USB Blaster II from altera. They gave me the required drivers, a program to program the CPLD, as well as a .pof file they created to program the ...
13 years ago --- Quote Start --- Now one question. In steps 1 and 2 you are doing the exact same thing for the exact same device. why would quartus ever not be consistent? --- Quote End --- Experience :) Quartus should *always* give the same synthesis result given identical files and an identical start seed. However, some versions of Quartus break this consistency as shown in my PCIe timing analysis tests; http://www.alteraforum.com/forum/showthread.php?t=35678 The advice to repeat step 1 as step 2 is a good sanity check :) Ideally you would synthesize your design via Tcl scripts, that way there is no ambiguity as to whether or not you repeated the synthesis steps exactly. Cheers, Dave
