13 years agoAltera USB-Blaster II Design
Hello, I was given instructions on building my own USB Blaster II from altera. They gave me the required drivers, a program to program the CPLD, as well as a .pof file they created to program the ...
13 years ago --- Quote Start --- Would a .pof meant for the epm570gf100 then work for the epm570gm100? --- Quote End --- If they have different JTAG IDCODEs, then its highly unlikely. Looking at the BSDL files ... http://www.altera.com/download/board-layout-test/bsdl/max2/max2-index.jsp The MBGA vs FBGA files IDCODE_REGISTER entries are the same, so it might actually work. Try synthesizing your blink LEDs design as follows; 1. Start from scratch and build for the MBGA device - copy it to test1.pof 2. Start from scratch and build for the MBGA device - copy it to test2.pof If test1.pof and test2.pof are identical, it tells you that Quartus is consistent. 3. Start from scratch and build for the FBGA device - copy it to test3.pof If test1.pof and test3.pof are identical, it tells you that the die must be the same, its just the package that changed. Cheers, Dave
