15 years agoaltera transceiver support burst mode?
Hi, is there any possibility for altera stratix ii gx transceivers to support burst mode operation? any ideas?
15 years ago --- Quote Start --- Hi Rick, I have heard of it, but have never looked at any of the details. What you describe occurs on the fiber. What happens at the optical-to-electrical interface? Is it simply optical-to-electrical conversion of whatever is on the fiber, or is something smarter used? --- Quote End --- It's simply O/E or E/O conversion, without smarter used. Or, you have to get specified burst mode CDR chips for providing recovered clk and data. Actually, I don't want to do this since I need to redesign the board. That's why I ask for some details of FPGA and it's capability to support burst mode operation. --- Quote Start --- I use basic mode. There are two clocking methods that I need to investigate; lock-to-reference and lock-to-data. In lock-to-reference, the transceiver PLLs lock to an external reference clock and ignore the CDR recovered clock (if there is one), otherwise you can switch to a recovered clock (in lock-to-data mode). There are status bits in the transceiver block that indicate whether there is a CDR PLL lock. It sounds like you could use something similar; when there is no traffic, and the CDR PLLs lose lock-to-data, switch them back to lock-to-reference, then when data comes, they can go back to lock-to-data. What you would need to investigate is how fast this can happen, and whether or not it will be sufficient to capture traffic. Given that the packet contains preambles, I suspect they are there for lock-to-data to occur. If you know the preamble length, and the worst-case lock-to-data time, you will be able to determine if it can work. Cheers, Dave --- Quote End --- It's pretty cool that you provide your design details. I really would like to look into the clocking methods you mentioned: lock-to-reference, or lock-to-data. Can the clock methods choose by configuration or external control? The preamble could be programmed by myself. Still, I have no idea how long it needs to be the worse case lock-to-data. I will check it out soon with two dev boards with Altera Stratix II GX FPGA. Where can I get more information or datasheet of clocking methods ? Thank you. If you have any questions on the high speed operation like 10GE, let me know. Rick
