SMS
7 years agoAltera Soft LVDS IP core (output not consistent with the input)
I am simulating the Soft LVDS IP core as receiver by passing a bit stream with IP core parameters configured as follows: Power Supply Mode: Dual (for 10M50DAF484C7G) Functional mode: RX Number of ...
IDeyn
Contributor
7 years agoHi SMS.
First of all, I would recommend to look at that video - https://www.youtube.com/watch?v=02lgfcxSjQA&t=45s
It's somewhat not exactly what you are doing (14-bit shown here is more complicated), but it contents also example design which you can examine with Signal Tap and ISSP for quick iterative testing.
- Had you tried bit slip mode?
- Which clocks your internal pll generates?
- Which output data rate did you choose?
The inclock frequency depends on the output data rate (input data rate & deserialization factor).
You can check in similar IP core datasheet here - https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altlvds.pdf
Ivan
