11 years agoAltera SGDMA & TSE
Hi all, I am working on TSE and is using sgdma for avalon_stream_to_mem descriptor, now in my code I have four descriptors,I am receiving network packets in my local buffer from sgdma in every sgd...
10 years ago --- Quote Start --- Also one question is that there are so many references like ucos ii interniche stack and lwip stack and standalone sgdma software. But none of them uses multiple chain logic. Is there any specific reason for this or people generally do not prefer to use multiple chain? --- Quote End --- I don't think any of these stacks are out-of-the-box optimized for absolute highest performance. They work well for their intended use, with modest performance on a modest processor. I think there is a general understanding that if you want to saturate one or more 1000mbps links, you aren't going to be doing that with a ~100MHz processor and software. See http://www.alterawiki.com/wiki/nios_ii_udp_offload_example --- Quote Start --- Hi ted, As you are saying that there is already support for multiple descriptors in interniche drivers, then can you tell me how to use it for multiple descriptors and/or chain? I tried with calling altera_sgdma_stream_to_mem_descriptor() but couldn't get it done. If we increase the value stored in ALTERA_TSE_SGDMA_RX_DESC_CHAIN_SIZE to 2 or more than it will be a chain with two descriptors. Suppose if I want to use sgdma at its maximum capacity than how should I go with multiple chain or descriptor? --- Quote End --- This is largely a repeat of the good advice Daixiwen already gave you earlier in this thread: Software driving SGDMA at it's maximum capacity would consist of a (very?) long circular chain of descriptors stored in dual port on-chip RAM with the other port of the RAM connected to the NIOS tightly coupled data memory interface. The software would basically consist of initializing the chain and starting the SGDMA, and then continuously process the chain looking for completed descriptors. You can either do that by foreground polling of the chain, or having the SGDMA set an interrupt on each descriptor and having your ISR process every completed descriptor each time it takes an interrupt. In order to do this, you will need to overcome whatever issue you ran into with your difficulty using the HAL API's altera_sgdma_stream_to_mem_descriptor() etc. as you're going beyond any of the readily available examples. You can get quite far with an approach like this, however at some point you will want to consider other options including the Modular SGDMA and developing custom IP for your fixed function.
